Ron McIntyre
Anyone have info on mag drives used on Model A, B, engines?
A mount for the mag can be fabricated and bolted to the B fuel pump bolts or the pan rail on A engines.
Sorry, I don't, and sold that setup years ago. I ground off a little of the sheet metal at the pan's edge to insure the mount always sat in the same way. Good luck!
I've got an "SM" Smiley Martin side drive with no mag base, and an unmachined Wells front timing cover and side timing cover.
If you see the attached photo, you can see both.
http://IMG_4215.JPG
Tried to post pic but failed, I had a good look at the magneto and you are right about the reduction drive, the rotor button itself is geared and drives off the main shaft 2:1.
And yes, I’ll be using a steel crank gear. The are obviously designed to run at crank speed and can handle the revs.
