pooch
Who in Australia machines rear brake drums?
I have contacted several chains, and they say the hole in the taper is too small for their brake lathes.
Modern drums are easily removable from the studs and the large centre hole fits the lathe cones.
I pressed out a front drum and it is a very precise fit on centre alone without studs (lugs).
Les Andrews book says to true drums after they are swedged on.
Easy enough with the fronts, but not the rears.
How critical would it be if I was to put a rear drum on a front hub, have it just centralized on the large hole and 5 hex bolts tight , machine it, then swedge it back on to rear hub?
I have a spare axle, so another alternative is to bolt the axle in the hub and hang the whole shebang in a centre lathe.
When I showed just the drum , to a local garage with a normal brake lathe, they said, just to cone it up and turn it, it will fit centrally back on hub.
I am not so sure with the early steel AR drum being so thin and possible flexing. while turning
But bolted to a front hub will make it more rigid when turning.
Are the aftermarket new cast iron drums just not precisely machined for instant use ?
What views do others have?
