May not be applicable, but several years ago, I had the 327 in my Corvette rebuilt. The rebuilder put a hi-volume, hi-pressure pump in it, which caused all kinds of problems. I replaced it with a standard Mellings pump. Not knowing the pressure it would put out, I contacted Mellings. I found out that they offer 6 or 8 different relief springs that would allow the pump to "blow off" at different pressures (the springs were identified by their color). Perhaps they have the same set up on their flathead pumps. You may want to contact them.
