lug nut removal
keyswitch1
Yesterday I found a video on removing the model a stud but now I can not find it. Could you help me out please ??
Where does the term "lug nut" come from? They go on the wheel studs so LUG nut??? Not confused, just curious.
“According to Google”.
The lug that shows up in lug nut or lug wrench doesn't seem to be directly connected. Instead, it comes from a word that meant a projecting part. Originally, it came from a Scandinavian word that meant the ear flap of a cap, or the ear itself. In the 1930s, lug also meant a lout, a sponger, a bozo, and a lowlife.
Probably comes from when using wood wheels, like on a Model T, there is a lug that goes between the wheel rim and the felloe of the wood wheel, and the "lug nut" tightens down against the lug.
Couldn't find a picture.
In Canada we just call them wheel nuts.
In a nutshell, you need to purchase a swage cutter to begin with. I know some people will suggest using a hole saw instead however I do not have any experience using that and I could see where that could cause someone to get hurt.
The swage cutter I use slides over the threaded portion of the hub bolt and is turned slowly in a knee milling machine. The cutter slowly removes the area of the hub bolt where the bolt was riveted. Once this is complete, the bolt can be tapped thru the backside of the hub.
Yes, wheel nuts on wheel studs here too, just like manifold nuts on manifold studs. Strange!
