Bob Johnson
A couple of years ago I purchased a set of Lucas tires for my Model A pickup. They cost approx $100 each. After 10,000 miles here are the results (see picture below).
The right rear tire shows extreme wear in the center. No it was not over inflated. It had the same 30-35 pounds of pressure as the other tires. I measured the "crown of the RR tire and it is taller in the center than the others even with the wear. The right front has uneven wear around the circumference of the tire. There are patches of wear maybe due to a tire that was not round when new.
I will not be buying any more Lucas tires.
Bob
Bob
