lubricating brake components?
I think most grease that mentions wheels should be rated to at least 500°F. Has anyone ever has their brakes over 300 - 350°F?
Regards
Bill
I use a molybdenum based dry lube. molybond 122L. Because it is a dry lube, brake dust etc doesn't stick to it. I also use the same lubricant between my leaf springs.
I agree with Dave. I use Rocol MTLM. A 50% dispersion of molybdenum disulphide in a bentone (non-melting) grease base. I use it on the distributor cam too. It is called "assembly and running in compound". The mearest smear suffices, leaving a thin persistent layer of moly dry lubricant behind.
SAJ in NZ
Thanks for the info. Obviously different countries have different items available and different trade names but following your recommendations I have found "Sealey Bentone grease for brakes" over here that claims to be "Anti-seize bentone (copper-free) grease. suitable for extreme heat applications including brakes and wheel bearings.Water-resistant. Wide temperature range...". probably makes tea as well...should do the trick.
