farmputzer
Should there be lubrication in the window crank mechanism, specifically the little cup and spring that hold the window in whatever position you leave it? If lub is recommended, what type?
So are you saying the cup and spring should be lubricated?
the main things i lube is the roller track on the window and the regulator teeth.
That's basically what I lube also. If the window glass is tight in the channel I might spray silicone in the side channels.
