FWIW: Wider Model A Tires ?
Verifying Exact, Current Model A Dimensions For The Installation of Wider Model A Tires.
A. Just in case anybody is cautious or even afraid of buying far better, safer, & wider modern Model A "Radial" tires, (like, e.g., Coker Radial 550-19 tires) ..... or thinking about installing any other wider size tire ....... one can easily verify "if" slightly wider Model A tires, can come in contact with, and usually hit only (1) front brake rod in lieu of both front brake rods.
B. Simple Wider Tire Dimension Test Verification & Possible Solution:
1. Turn steering wheel all the way to the "right" and measure distance from in-side of existing installed tire to the nearest brake rod; and,
2. Next, turn steering wheel all the way to the "left" and measure distance from in-side of existing installed tire to the nearest brake rod.
3. Afterwards, one might clearly see that in many cases, through the years, Model A front wheels may turn more in one direction than the other.
4. "After" performing front wheel/tire equalization adjustment, one can now measure distances & verify whether or not proposed wider tires will contact brake rods on one side ..... or on both right and left sides.
Hope this can help someone in the future.
