Lowering the back of a Pick Up
Herb Concord Ca
Hi all, about a year and a half ago, I posted a question about how to lower the back end of a pick up.
I have a 31 Roadster P/U and the back end is too high.
I received a few replies most saying take 2 leaves out of the rear spring, but not saying which ones.
Then Jim Brierley replied saying install a Model T spring.
So I took his suggestion, got a T spring, cleaned it, nosed the ends, and sprayed dry graphite on the bottom of each leaf. Just finished installing it this morning. WOW what a difference, the T spring gave me a 2" drop, and the bed looks level!
Thanks Jim,
Herb Neumann
Concord CA
Hi, I am building a model a boat tail speedster, what model t spring have you used the early or the late, also is it hard to spread the spring to fit the model a axle, I would like to drop it 4" if possible, my body weighs about 350lb... thanks, Jim
