Just the obvious stuff… push the hose as far as you can in one direction. I usually put the hose on the radiator and push it as far to the front of the car as I can. I do that with the hose clips “on” but out of the way. Then I try to work it over the inlet end of the water pump by twisting the hose back and forth to walk it on to the pump. I sometimes use a pick that has a right angle bend in it, to get under the hose and pull it over the water pump inlet. With the pick getting me a little more of the hose around the pump inlet, then I can twist it on. Then center the hose and tighten the clamps. Definitely not a very easy job. Harbor Freight has a cheap pick tool set with straight, right angle and hooked tips on what look something like screwdriver handles. Good luck; I know how difficult the job is.
