gdmn852
Started working on outside lower deck panel, mentioned on deck led fit post, didn’t want to hijack original so created this one . Notice that the repro panel was almost flat across the top ,I removed the inner channel at the top of both and original panel, not held in by much a few spot weld on an angle tab at the side. Inserted the original into the crimped over slot that is at top of panel made up some angles to weld to , increasing to bow to 1 and 1/4 at center of panel. Another solution would be if you have an English wheel more bow could introduced . Still working on fit to deck lid will up date later.
