FlatheadTed
1927was a good running car but on 12 volt ,but its now got a 6 volt battery in it .It has been in storage for some years but started occasionally ,Runs but is low on power stalls at low speed manoeuvring into garage we had the
AdV leaver down about a I".Smokes at low speed ,We Lean the mixture out and it seems to idle better am smoke diminishes , but fluctuates or gets low on power (Float ,Needle valve ) ? ,We have tried to put more advance into it ,coils all working on shorting them out but not sure about double sparking etc .Good compression ,The owner puts CRC on the timer ?? .We had the manifolds and carb off but now replaced with new gaskets Thanks for any advice .Ted
