g8t gr&dads A
I have lost the spark at my points. I have been using Les Andrews troubleshooting book to figure it out and one step calls for checking continuity between the movable point arm and ground. My results show a closed circuit. Following it back the lower plate also shows a closed circuit between the ignition cable and ground. The only way I can get rid of this closed circuit is to unscrew the ignition cable from the distributor. The ignition cable and switch passes all the tests out lined in the Andrews book. It seems to me the problem should be in the lower plate and ignition cable area but I can't find it. Any ideas what I am missing? Thanks!
