Lost ignition key
Does (did) your ignition key operate the door lock? If so, you can take the door lock out and order a key by the number on the door lock.
If you don't have a matching door one Under the barrel there's a 1/8 brass plug drill that out and remove the barrel its a about 1/4 " deep ,on the end there's a number take that and get one cut .Ted
Good suggestions. On the '40, the ignition key opened the passenger door, so I took out that lock cylinder, for the code off it, and gave to an old time locksmith who looked up the numbers and cut a key for the ignition with them. The old one was so worn out, it wouldn't work. The code might look something like this; FK799, he looked it up on lockcodes.com, and it gave the cuts, depths, and key blank #s.
Been there,take the passenger door lock out and get a key made for it!
Once you have the door lock cylinder out and the key code read, if you can't find someone locally who will cut you a key, send me a PM and I can cut you one using my Curtis key cutter.
FlatHeadCoupe
Barners...A shout out to John McClure .... who made me some great keys and shipped them quickly....A good guy to deal with...
Thanks to Flathead coupe. He fixed me up with two keys for my Ch. y. Very quick shipping and they worked like a dream. Thanks again!
