loose vacuum tube
artron9
Hi Guys
I found a loose vac tube under the dash on my 52 Vic. One end, I believe is attached to the vacuum thermostat valve located within the heater plenum on the right side. This tube is 1/4 inch and has a plastic tee inserted the middle of the tube. I cannot figure out where the end of the tube attaches and where the other end of the tee goes.The shop manual and the parts manual do not clearly show these. The parts manual says the tee attaches to the wiper hose and the temperature hose but the schematic does not show this. This is not a critical problem but I would appreciate any advice you have? thanks Ron.
