My distributor housing is loose in the head. It can't only wobble side to side but also rotates slightly. How can I tighten the slop up? I believe the slop will affect the timing. I don't want to tighten the set-screw too much.
The internal bushings are in good shape. My issue is the outside casting of the distruburtor to the head. Maybe I should add some shim-stock around the distributor to tighten up the slop. Your comments would be appreciated. Bob
