fivefix
I was on a club tour last Saturday and was enjoying a perfect Iowa fall tour. I am running water with a rust preventive additive and water wetter. I have a Vintage Precision thermostat gooseneck with the thermostat removed. My temperature for most of the day was running 150 degrees. A little cool I realize, but the weather turned form blazing hot to cool in Iowa within 1 week and I didn't get the thermostat reinstalled.
Shortly after lunch I glanced at my temperature gauge and was pushing 210 degrees. We pulled over and discovered my crank pulley nut had loosened allowing the pulley to slip off the crank key. The fan belt was barely turning so I had no water pump or alternator. Luckily I was 50 miles from home so I parked the car in a farmer's drive, jumped in another A to get home and got the car trailer.
The timing and crank gears were replaced with a Dan McEachern matching set this past winter so I only have driven 3,000 miles since the crank pulley nut was last tightened.
Is there a way to ensure the nut stays torqued? Does anyone use a star or lock washer? I hate to use Locktite.
Dave Fick
Muscatine, IA
Dave Fick
Muscatine, IA
