Looking for repro FORD script coil
I have this one if someone needs it. I have no use for it so $50 would be plenty. Just pm me if you can use it. Not sure if it works.
565766
I was using a coil like this for a long time, but last week it died - the secondary winding is open. Is there any possible way to repair it? Is that sleeve that holds the top in place soldered on? Or should I just toss it?
Doug
The amount of work to repair a coil is likely way out of proportion to its value. Remember the components are (best case) immersed in oil or (worst case) sealed in hardened epoxy.
Doug, Empty the can and put a new coil inside. Find a new coil that fits inside. I think most of the ones that you can buy from the dealers will fit.
"The originals generally had a permanently attached bracket. " - the one on my car is like this. (March 1928)
I have one that I would also sell for $50 plus postage (probably under $10 in a small box), since that seems to be the going rate for these rare script coils on this website. There are no dents. I don't know if it works, but I have no reason to think it doesn't. $50 as is plus postage, working or not, rain or shine, pretty much cleaned to bare metal.
Marshall
Most of the original coils I've seen will work when you get started but lose strength quickly as they heat up.
My coil just died, but would like to retain the original appearance. Just ordered a Petronix replacement. Does anyone have any guidance on how to mount a new coil in an original can? How are you holding it in place? How are you cutting the original can? And what happened to the suppliers for the repro coils?
