looking for flathead parts 51-53
52fordv8
fayetteville
west virginia
looking for flathead parts . im needing a nice useable 3 blade fan assembley with bearing and narrow belt pulley . and im needing the bottom crank pulley 2 grooves with the winged opening in them i have pics of what im needing im converting a truck flathead to fit into a 52 ford car so have pic of the crank pulley i need . and fan type i need here is a pic of a front of a 52 ford flathead car engine i need the crank pulley u see and a fan assemble like that is on here . for starters will need other things too like a narrow pulley gen or a pulley off a gen and rear dump manifolds .
update on parts found i just baught a fan assembly . and set of car pumps . so still on the look for the bottom crank pulley like in the pic here and a narrow pulley generator or just the pulley for a gen thats narrow belt if someone has one off . and if anyone may have a good used eab carb thats right for a 52 ford car . one that is useable as it is . or least a clean one that can be rebuilt . .
