john charlton
Just watched a 3 yr old video where a long shaft was fitted . I just dont like these as it assumes the head is perfectly aligned to the block which I would bet could be a couple of thou out . The short shaft top and bottom slots are offset to each other so act as a sort of universal joint . When I oil mine I "twizzle" the rotor to check the part rotation is not stiff . I recently had one which was after several thousand miles,food for thought .
John in sunny warm Suffolk County England .
