update on this 36 Coupe: My son and i got the 21 stud engine running with little effort. Just routine stuff - points/ condensor, carb kit, plugs, temporary fuel tank. It fired right up. The engine sounded really strong, frankly. Compression decent right though all cylinders. The typical seal leak, however, and within 48 hours 4.5 quarts of oil would follow the path of gravity. This wasn't necessarily a bad thing, though, as there was no marking on the block to signify LB (or not), so i really wanted to check the mains. Was it babbitt or the more desirable insert bearings? i also thought it best to check the sludge level in the pan.
Fast forward a week: it is an LB block/late 36 manufacture. And a surprise bonus - standard bore. The oilpan and pump screen were clean as a whistle. The valves look like new, as do all bearings. Was this vehicle parked right after an overhaul? Who knows? I did find one perplexing thing, at least for me. Check the photos showing two pistons and rods from this same engine. What are the thin pieces of metal affixed to the underside of some of the pistons? They appear to be affixed around the wrist pin and fasten to the inside of the pistons. Some are broken, some are missing. Half of the pistons are equipped in this fashion. i'm going to tank the LB block. Should i reassemble the block as it came apart? Should i find a new set of pistons? Or, should i just remove these metal strips so all match? 'Hope this isn't a stupid question, from a relative novice. Thanks for your input.
