- City
- Siler City
- State
- NC
I am looking for a locking scroll driver's side handle.
See the photo of the passenger side handle I have.
The stem is 3 5/8" long from the bottom of the flat eschuteon. The end of the stem has a drilled & tapped hole. An exact match is not necessary as long as it has the opposite curl. I can also install a flat eschuteon and make the stem as needed. As a last resort, I could use another one of the same hand I have, since they will not be seen together anyway.
The window crank handle is similar to what I want. OEM for my application would look like the picture, but instead of attaching via the set screw in the hub, there is a counterbore so a screw goes thru the handle and into the end of the crank mechanism stem. I need a pair of this handle.
I check my home email frequently, but not so with my Ford Barn messages, so for quicker turnaround you can email me at: jea777@centurylink.net.
http://s1197.photobucket.com/albums/aa437/jea777/Woody handles/
Thanks,
James
Thanks,
James
