Locking lug nut
daoust
I was at the Eastern National Meet last week in Gettysburg, PA. In one of the 47 Fords I noticed a special nut that was used on the bracket that holds the spare tire in place in the trunk. Apparently it is some type of locking lug nut with a thick square washer. Does anyone know exactly what this nut is called and where they can be found? Any help appreciated. I'd like to find one for my car. A picture is attached.
Thank you.
David Daoust
David, the nut you pictured is part of an assembly that included a keyed lock that clamped over the nut. Ford part # 48-18312-B was introduced in 1935 for the 1936 model Ford, and continued as standard equipment on open cars having spare tires outside the trunk, such as my own '38 Convertible Coupe. My spare tire is behind the driver seat, accessible to thieves, therefore the need for the lock.
David: There are several versions of the lock nut. For the application you have pictured the nut does not appear to be correct since it has a wheel nut chamfer on the side for the flat washer. It would appear, the nut pictured, is supposed to fit in place of one of the wheel lug nuts.
I think the correct part number may be 78-1462-A or 77-1462-A. Not sure if the square washer shown in the picture is correct and if so, what the part number is for that. Sooner or later I'll find it. I love the hunt.
The square washer looks similar to one used with the generator nut ---on my 46 it came with the nut and lock, it was keyed the same as the trunk lock, there was no washer
The 36 conv sedan has a different "nut", the head looks like the nut in the picture, but it has a stud ---about 3/8 that screws into the trunk floor
I have found the nuts in junk boxes at flea markets like Hershey for 1$, there are several versions, and some other make cars used similar parts
I have one version of the locking lug nut as Alen described in his post. It has the lug nut locked in place and, of course, the key is missing. If I can put my hands on it today, I will take some pictures to post here.
These locks should also be shown in some of the V-8 Clubs restoration books.
