Lock Cylinder for Locking Hub Cap
v8fordman
Lexington
NC
Any of you Fordbarner's have a lock cylinder for a locking hub cap? I need the one which is the smaller diameter. I think they were used in '32 and perhaps some '33 locking hub caps. Again, this is the smaller diameter of the two types that were made. I have a larger working diameter cylinder with key for trade or sale.
They're both the same diameter over the majority of their length. The difference is in the length of smaller diameter end which is longer in the '32/early '33 version. If you can't find one, the later cylinder can be successfully turned down in a lathe to create the desired length.
