H hermanthegerman1953 Junior Member Nov 16, 2013 #1 How do you get the lock cylinder into the trunk sleeve does that pin push in or do you have to pull it out? E-mail me at haw96aii@yahoo.com Thanks Herman
frank long island Well-known member Nov 17, 2013 #2 if its like the ignition push the pin and turn the cyl with key if memory serves me correct
Daves55Sedan Well-known member Nov 17, 2013 #3 You need to turn the key in the lock first, then you push the pin down, and pull the cylinder out of the lock
