If you find a dead miss like Charlie & Bill describe the next step is to find out why. Trade the dead coil for one of the others that is working. If the miss follows the coil, the coil is in trouble. If the same plug is missing it could be the plug, the timer to coil box wire, the spark plug wire, the timer or the contacs in the coil box. The plug is easy - install a known good plug. The rest can be checked with a multi meter. You really need to know what is broken before trying to fix it.
