Thanks Kerk, That's not too far from where I am. I will look into it.. I don't see the time, but I'll find it. Thanks again!I recommend investing in a new OEM harness which will come with directions and should be easy to install. The attached thread identifies a couple of manufacturers on the East Coast. I used AnZ in CA and their product with the integrated turn signals was great.
http://www.fordbarn.com/forum/showthread.php?t=206311&highlight=Wiring+harnesses
Alright, armed with this new info I'm ready to go back to it'It should be fairly simple to wire (I know it doesn’t seem like it!). The above suggestions are good, or if you have a specific question you can always ask it here. Any of the prefabed harnesses should make the job much easier.
I have a 1939-48 Ford manual, I have gotten along ok so far but I need to get my act together.What are you using for a wiring guide?
