chopnchaneled
Looked and didn't find anything other than won't work with multiple carbs.
any one tried it?
Thanks
any one tried it?
Thanks
I wonder about this also, some Y blocks had load-a-matic... any of them a four barrel?
Use a "ported/timed" port on the 390 should work very well . The loadamatic only needs a small venturi signal ( 1-4 in) , depending on the engine may spark knock with too much advance ?
You would use full manifold for the Mallory dist. and timed /port for the loadamatic.The carb has ported/timed and full manifold connection ports. Does the this vacuum diaphragm work same as loadamatic?
What all did the holley 390 come on ?
Thanks again
Thanks 51 Merc for confirmation, I tried both, that's how I have it now. Thanks V8 Bob, I was unaware of 2 versions of 390 cfm. I have #8007.You would use full manifold for the Mallory dist. and timed /port for the loadamatic.
