Chris Haynes
It should run warmer as the aluminum head dissipates heat better.
But you have to remember that Henry used iron heads as orginal equipment.
I like my Model A mostly the way it was originally designed, double clutch and all
You use the clutch to shift? I learned to shift my first Model A without using the clutch when I was 16.![]()
Hmmmmn. Terry Burtz makes parts for Snyder's. He is also having foundry problems. Could Terry be the source for Snyder's head?![]()
Vic,
I, just like you, bought one some time back.
I just installed the Lion Head III cast iron (LSH-III) on an engine I built up for a future project. Two weeks ago I installed it in my Phaeton for testing this summer. I do not have it dialed in yet as to maximum spark advance. I am currently running at a max advance of 28 BTDC and find it is very strong above 2000 rpm. Felt strength from idle to 1800 rpm is not much different than the 5.9 Brumfield on my previous engine in the Phaeton. Acceleration from 50mph to 60mph is quick using a stock Zenith and all the same equipment as the engine with the Brumfield...I am working on a new intake and "B" carb to add additional cfm at the upper range. I expect it to increase the power at the 55 mph mark. If I advance to 28 BTDC prior to reaching about 2200 rpm, there is what I detect to be some pre-ignition noise. I'm a bit concerned that I will need to be more mindful of how I set the spark. From my observations with limited road testing, the Brumfield was much less sensitive to the spark advance in all the rpm ranges than the LSH-III. Granted...the engine is different and there may be some other factors entering in. If you wish, I will keep you informed.
Good Day!
Dave in MN
Dave, I enjoyed reading your post and value your input
Follow-up:
Well, I have it bolted on and it's paid for so I'll see for myself how it works. Given its sensitivity to spark advance, maybe it would companion well with a distributor that had centrifugal advance. I don't have a distributor like this to try...yet!
Vic, I just re-read your post and realized you were referring to an "original" LSH. I had purchased a LSH-III. I don't know if there is a difference.
ADDITIONAL REASON: (added after further testing) The extra weight of the Lion Speed Head is not detracting from the acceleration of my car. WOW! This thing really pulls hard above 1800 rpm. HOLY MOLY...
4/22/2014 Late last summer, I removed the head and hand softened all the sharp machined edges to eliminate any potential heat risers. Re-installed it and it is working well. On my engine, I have found the LSH-111 head performs best at about 26 degrees of advance. More advance is not adding power. I installed a FSI auto advance distributor and it compensates for the head's variable timing needs well. Lots more power than my other engine with a 5.9 Brumfield. The Brumfield produces 55hp with Nu-Rex electronic spark...manual advance. The Lion Speed Head lll, with same carb and exhaust but FSI Ignition, puts out 68hp. I judge the ignitions to be about equal so the head is making about 13 more horses.
Good Day!
Dave
Hey Chris,
Answer...NO !
Do you know who makes them?
Dave, I enjoyed reading your post and value your input. You say that you figure that the Lion 111 gives 13 more horsepower than the 5.9 BF head. This is very interesting. I'm wondering if your lion head is six to one or seven to one? Thanks Purdy .
Thanks Dave, I don't doubt your calculations. I was just wondering which head to buy, 6 or 7 to one. Charley once told me that the counter bore was plenty deep to mill his heads to 8 to 1 or more .
Purdy, The LSH-111 is currently only available in 6.5:1 from Charlie... unless he agreed to mill one for you. The earlier version LSH-11 was available in 7:1 and 6:1 compression ratios.
Dave
What needs to be done to the version 0ne head to make it better?
anyone?
