The unique L-Z gears include the cluster gear, main drive gear, and second gear. There were just two possible sets.....the second gear has the same tooth count in either combination.
a) cluster (25-22-18-14) + main drive (19) + second (24)
b) cluster (26-22-18-14) + main drive (18) + second (24)
I believe the 25 tooth cluster only came with the 4 slot rear face for the single thick thrust washer. The 26 tooth cluster gear came in two versions: the 4 slot rear face or the two prong rear face for the two piece thrust washer.
