The V-12 in my opinion is a GREAT engine, and designed oddly. Is it essentially two 6 cylinder engines (study the crank and ignition on one and you will see what I mean.
While I have only messed with a couple, if you rid yourself of the hydraulic lifters and have the separate ignition points timed properly they run quite well and are incredibly smooth. They do not seem to have a lot of torque or substantial power, but when properly set up, seem to run smoother than the V-8 counterparts.
