Lincoln Hypoid vs Ford banjo rear
SUHRsc
Does anyone know off hand if you can interchange Ford axle bells and axles onto a Lincoln banjo rearend of the hypoid type?
My reasoning is for a sedan delivery that will tow a trailer, I'm wondering if the stronger center section would be beneficial along with the lower ratio if mixed with an overdrive to make up the top end.
The width of the Lincoln will not keep the back wheels inside the fenders as-is.
Thanks for any advice.... trying to save opening it up if its a big waste of time.
Zach
The shim gaskets between the bells and the center section are the same but the bells are probably longer. The Lincoln axles will be longer and maybe a little thicker, but the taper is the same. All in all you should stay with the Ford rear.
Thanks! That's what I was wondering. If I can put the ford bells and axles on the Lincoln center. Seems like it.
Don't think the ring and pinion gears are the weak link on the banjo, it is the axles. That was/is the reason for switching to the 9 inch Ford axles.
I would wonder how easy it is t find parts for the old Lincolns. I'm sure there are still some out there but the supply might be limited on gears and ratio selections.
For example, the 40 L Z rear axle is the same width as the '40 Ford axle. The LZ spring hangers are heavy duty and use a larger size shackle & pin.
