1931 flamingo
Finished up installing turn signals on 31 tudor sedan y/day. I'm using 2 orig ford foglights on the front and 2 thru the bumper lights in the rear. All wires routed thru orig stule loom to a bussbar mounted to left cowl w/magnets, fused, behind left kick panel, then up to controller (Everlasting). I had a problem getting light on controller to flash when signals on, sprayed internal contacts with contact cleaner, works OK. The problem is the two rear lights are on ALL the time, when signal is activated they blink correctly but remain on. I assume (I know) that something in the controller (4 way flasher) is messed up. Any thoughts? Replace controller?, which is what I'm leaning towards. Thanks in advance.
Paul in CT
Paul in CT
