Rust Merchant
Hello All,
I have a ground out problem in the lighting harness. I disconnected power from the generator; tried to reconnect; got 3rd degree burns immediately on my fingers! Immediate arc! Today I pulled harness off of the steering column and found it full of grease. Is this normal? Could this be causing my problem?
As you can see from the pics, this harness is OE. The fabric pulled off with no effort and was rotten. It has add on, poorly done, turn signals (I'm fixing that); they were connected to power separately from the rest of the lights, so I know the short isn't in this system.
I have plenty of 14 ga. wire and experience wiring cars. Should I buy a harness for $55 and replace or run it down myself? Left headlight worked intermittently before this all started, so I'm thinking it could be there. Horn is inop too. By the way, I wiped off the harness end before taking the pic. It was so covered in grease that you couldn't see the contacts.
Thanks,
Dwight
Thanks,
Dwight
