I finally decided to overhaul the transmission in my 30 coupe. While I had it apart I pulled the flywheel to check the runout of the flywheel housing, good thing I did as it was .015 should be .006". Before removing the flywheel I was warned that it was heavy at 63 lbs, mine didn't seem to weigh anyway near that,... so I weighed it at 35 lbs.
Just wondering...what are the pros and cons of a light weight flywheel. My engine runs great although it will not idle as slow and steady as I have heard other A's do.
Dave
Dave
