Gord. B by the bay
What is the maximum weight that may be removed? Many Thanks Gord. B by the Bay
The one in my tudor is 45 pounds.
I had mine lightened to 38 lbs. I have seen others say they use some as light as 9 to 12 lbs, but they're aluminum.
That looks cool.... but I like my legs a lotGuys, are we not reading what the man's question is?
Gord, you can safely remove about 42 pounds from an 'A' flywheel if you use the stock pressure plate, --and about 45 pounds if you convert to a V8 style pressure plate. THAT is about the maximum amount of weight that can safely be removed. The one below was in Pennie's race car for several years and has been 'spooled' many times over 3,000 RPM's.
A 49-53 Ford V-8 flywheel weights about 29# stock. They may not be drilled for a 9" Long type clutch which you will want. Most were drilled for 10-11" clutches. The starter rework involes reversing the the old style bendix, milling a keyway near the output end of the starter, machining that end plate and using one of those bendix springs you bought at the swap meet that when you got it home it was backwards. Maybe the real trick is providing a "third" starter bushing in the bellhousing to support the shaft end. I have the infor to do this and have done it, so if you are thinking about this I could send it to you. If you decide to go with it you could call me(your nickle from the Maritines) and I will got over it with you.
Steve-Santa Rosa
You are putting words into my mouth that I did not say because I never stated they couldn't explode! You are also comparing apples-to-oranges in my opinion. We are not speaking of SB Chevrolet engines, we're not turning 6000 rpms, ...and please explain the picture of the pump being driven off the back of the camshaft where the stock flywheel would normally reside. "Most likely" there is more to that story than what you are eluding to. Bottom line is if you do not feel comfortable with my flywheel or how I have used it, then kindly move on and your opinions reserved.
A little defensive there Brent, he can say what he likes, in 10 UHHHHHHHHH c
Your answer was not much better than ours. We posted what our flywheels are as an indication of what could be done, because it HAD been done. That, while not answering the question exactly, was useful information. Your answer said "about" in your figure, so it also is not an exact figure. Stop finding fault with people who are trying to help.
