I have a 1928 tudor. I am replacing the lighting wire harness and switch at the bottom of the steering column. The problem I am having is the very bottom of the steering box where the light switch fits into to mate up with the spider from the light/horn rod turns and causes the switch assembly to rotate when turning the horn rod at the steering wheel. I figured I had a bad piece on the bottom of the steering box so I got another steering box I have and it is the same way. So I don't know if I have 2 bad parts of it I am doing something wrong. Every time I fit the light switch to the steering column and snap the bail wire in place to hold it all together I have the same result. As I turn the light switch at the steering wheel the switch assembly moves with the light/horn rod and it all comes apart. It is a 7 tooth steering box if that matters.
Thank you for your time
Joe
Joe
