Vicky
I have a question regarding the Light Switch Assembly.
The Horn Rod is installed, and the Spring & Clip correctly installed on the bottom. The switch was properly installed and all lights and horn work correctly. As you move the light switch through the different positions, you can not "feel" or "hear" the switch engage at the different contacts.
Is there a spring that pushes the "wiper" on the Upper Section of the switch to the lower contacts of the switch ensure a more positive contact with the lower section (the part with the wires connected to it)?
I was helping a new owner that had removed everything from the steering box and could not get it back together. I could not find enough information regarding the switch assembly in the Service Bulletins or the Les Andrews Manual. I am just trying to get it to operate correctly.
Thanks for any help.
Bob
Bob
