Since I purchased the new wiring harness, the switch is very hard to move from one position to the other. It does NOT work smoothly at all... never has. I can remember that the wire bail was very difficult to get on. Now, that I have got it off, I can see deep scaring, on the dimpled connectors, from the rotating connector. To me, the whole housing should fit correctly regardless of how hard the wire bail is to install... Regardless, the switch is far to hard to turn and is destroying the light connector... now, I am having problems with the tail light staying on.
