headonz
I am about to connect the connector block to the light switch body and want to remove all the spade connectors so I will be able to pass all the wires through the large whole in the light switch body and reconnect all to the connector block.So far I have been able the pull all the spade connectors off the connector block but one.The central horn connector.I cant tell if this is soldered solid to the central pin or should just pull off .
Thought I would ask before I break something ??
