Lawson Cox
I believe I have everything set to go on the horn situation, EXCEPT getting the switch housing bail to hold the switch cover on. Everything seems to be in proper position, fully seated, however the bail wire just will not go on. It seems like it needs to be about 1/4 to 1/2 inch longer. (If I remember correctly, it was not fully in position when I started fooling with it, and everything worked except the horn.
My set up is a 38 steering column and 37-39 worm gear set up, and I believe a 37 wiring harness. That doesn't seem like it would be the cause of my problem.
Apparently there is only one bail wire for these switches covering this period. Is that correct? I think I need to put a spacer of about 1/4" to 1/2" in each "Leg" to allow it to go on, or use zip ties, or something. Any suggestions??? Would be hard, delicate job to weld in such a short spacer on this relatively thin wire.
It's driving me nuts. (More so as I am half nuts already.)
