bnchief
I have my steering gear back together and put the column back on steering wheel tightened it up good put the horn rod bushing in the steering shaft and then put the horn rod in the bushing fits tight on the horn rod, should it or should it be free or should it be tight in the steering shaft when i turn the wheel it moves the light rod this is without the light switch attached just trying to eliminate issues beforre i put the column back into the car.
