[QUOTE
Heh heh heh! Remember the old days??? When engines got repaired, not totally torn down and scrubbed and fully re-machined??
Valve job, anyone, or even a ring and valve job done with engine in car?? On Chevys, which had chronic rod problems, it was routine to turn a crank throw IN THE CAR* while replacing the rod that had just beaten everything to death.
Metal shavings, Clover coarse and fine emery, ring honing, blood, EVERYWHERE.
Cleanup...shop rag, mebbe a paint brush dipped in gasoline...
The whole damn national supply of cars worked this way. For a long time.
Again, less than optimum, and FAR less careful than an experienced enthusiast would do verboten things like this.
*(edit...this was done with a tool that looked like a big tubing cutter, equipped with a bit like a lathe cutting tool...really!)[/QUOTE]
Bruce, Thanks. Glad to see that someone else remembers. My experience and training also came from 'these days'. I still try to operate in this manner, at least on my own stuff. Problem is, it is very hard to find 'cooperation', today. Remember Chevy's? On certain cylinders, you could actually change a rod from the bottom, without removing the head.
I recently found a guy who still operates a crank-grinder, for in-the-car repair. I'm having less luck finding someone willing to do a bore-job on an assembled engine. They all seem to want a disassembled block, **** n span, and 'clean-room' environment.
As for the lifter question... I'd go for it - of course, taking precautions & catching all the chips. It really shouldn't be all that difficult.
And, by-the-way, my experience with those Johnson lifter tools, has been very poor. They were never very good 50/60 years ago, and the ones that I still have, are still no good today. I don't generally try to use them. Last adjustment I did, I removed the valve assy & lifter, make small adjustment, reinstalled, checked, and repeat if necessary.
