flathead4rd
I have one (1) lifter that won't hold it's setting. Can this be fixed without having t0 remove the head? If so, all suggestions will be welcome.
Belt and suspenders: Extend the adjuster to expose the threads that were in the lifter threaded area. Clean the oil from the threads with brake cleaner, Place a rag behind the threads to absorb as much as possible. Use a suitable tool to "ding" the threads that will be in the lifter when adjusted. Apply loctite and readjust the clearance.
