outsider347
What dia hole suggested in the lifter bore for the adj lifters?
Tks
Tks
Depending on the type of cam you are using, I may suggest scalloping the top portion that faces in towards the valley. With a high lift reground cam, the adjusting screw on an adjustable lifter an sometimes sit below the top of the lifter boss which makes it hard to turn the adjusting screw.
Remember................ The lifters were made for stock valves and cam. They work well on cams with up to.350 lift. More lift requires the adjusting screw to cume out of the lifter creating a loose condition and noisy lifters. The easy solution is to use the SBC 1.5 valve which is .060" longer. They also make a larger 1.6 valve winch will allow you to repair a bade seat with out using a seat insert .
Gramps
The lifter hole info is great - comparing a stock lift cam to your new cam should give you an idea of where to drill your hole as you look at the groove in your lifter. What I have been taught is to get one intake and one exhaust valve set up with your adjustable lifter and set the rest to that measurement to make your adjustments that much easier/ closer to what you need for the other 7 cylinders. I might be stating the obvious to most who have done builds but I figure I would throw it out there …
I would like an illustration on drilling and dishing bore, so chip cleaning could be done early before assembly. Newc
