Can you really get rid of it, and how. I recently started to get all the parts sorted for my 31 std. Roadster. Many parts were stored in a dirt floor barn by the PO. All the floor pans were new at one time but now are covered in rust, not deeply pitted but covered in rust so that a wire cup wheel on a grinder pushes it around but not clean enough for paint of any kind I think. Many other parts are like that as well, the rumble lid I sanded down had rust areas that when wire brushed after sanding appear as dark pitted spots or areas. So what do you do, if I grind with a 36 grit pad I can remove them Maybe but most of the metal is gone too. Has anyone had experiance in dealing with this sort of thing.
