Tom Wesenberg
today I took anti spueek out and chamfered top leaf, still cannot get castalation nuts to reach a point where I can put cotter pins in...vender suggested grinding castalation nuts down till cotter pins fit...kinda mickey mouse to me...Burt's did not have answers and did not suggest a solution to their spring not fitting...may not use them in future...
What does the new spring measure for thickness?
Does the new bevel you ground match the original spring bevel on the top leaf?
Any chance someone welded a reinforcing plate inside the front crossmember?
Are the U bolts the correct ones? Most repro U bolts I've seen are too long and need to be cut and new holes drilled for the cotter pins.
