Terry -
As the guys above have said, this is at best a two man job. We replaced running board brackets and a few cross member rivets on a project of mine a couple of years back, and we actually had three of us involved - one to hold the dolly on the back side (be sure to wear some heavy gloves), another to hold and heat the torch, and the third to immediately run the rivet gun before the rivet started to cool down. As others haved also stated, the rivet will cool very quickly once you pull the torch away, so the sooner you can get the rivet gun and bucking bar loaded up the better. Its not a very difficult process, although some of the rivets are much harder to get a dolly in behind than others. Good luck with it - you'll do fine.
Dick
