4dFord/SC
The blower in my '40 hot water heater recently quit working. There was power at the switch (the indicator light worked), but no blower in any of the four positions. Assuming the worst, I immediately concluded that the motor was the culprit, and had visions of removing the heater, disassembling it, and sending the motor out to be rebuilt (hopefully). I was then reminded that most problems have a simple explanation, and decided to check everything one more time. Crawled back under the dash (feet over seat back, blood rushing to head, etc.), and in retracing the wiring found the ground wire had worked loose. Reattached it, and VIOLA!--everything works again. Once again, turns out the glass was half full, rather than half empty.
