Mr 42
There been some discussions how to shorten/make a Propshaft.
This is how i lengthened mine since i had a 1934 Four cylinder propshaft.
But needed a V8 that is around 45mm longer.
Please This is how i did it it's maybe not the best way but it's my way.
And ive been driving 8000km plus without problem.
Just for the record I did the lenghtening at the rear axle end.
Maybe it can be of some help or give you ideas.
I used a water hose clamp, to get a straight cut.
Used a hacksaw to cut it going slowly.
Used a rotating file to clean up the inside a but since there was a bump after the tube was welded together.
Used a lathe to cut down the extension bit to the inside dia of the tube.
OK the thickness of the material was maybe overkill but it was what i had laying around.
Made this two holders using some skateboard bearings.
Welded the holders to a long pipe, so i could lay the propshaft on the bearing's and spinn it by hand, to check for roundness.
I had to stagger the bearings on the gearbox side because of the small diameter of that end.
Before i cut it i used this dial indicator, and then during and after i welded it back together, so i didnt get into trouble.
As i said in the beginning ive been driving 8000km plus, without any problem, i took it apart a couple of weeks ago since i goofed when welding the rear sprint, and it loosened, Everything else looked OK, So im happy.
